70's Sears Gamefisher power head removal
twocyclemania
I have a 70's (I believe) 15 hsp Gamefisher. I'm trying to remove both the power head and the lower unit. I can't get either off. I've stripped and unbolted just about everything I can think of yet I cant get either off. For ID this motor has a white cover with a green stripe decal. Did they weld this motor together? I've worked on Evinrude, Johnson, Gale and both the head and lower units are a breeze. I can't figure this motor out. What am I missing? Help!
M
mrcrabs
Guest
Re: 70's Sears Gamefisher power head removal
PB Blaster, turn it upside down and spray PB through the mist holes in the leg and let it set. You drive shaft is most likely rusted in.
