71 100hp johnson ignition problem
efreak29
i have a 71 100hp johnson and i cant get spark to the plugs is there any way to test the amplifier without a s-80 or m-80 tester?
patrick4266
Re: 71 100hp johnson ignition problem
unplug the wire from the amplifier, the one that goes to the points and ground it out. If it is good it should spark a little.
efreak29
with key on, off, or while im turning it over
patrick4266
key on and you do not need to turn it over
patrick4266
it is the only wire that unplugs
F_R
Since you know about the neon testers, I assume you have a service manual, right?
OK the earlier suggestion was alright, sort of. Here is what you should be doing:
1. First thing first. Do it in this order. With a voltmeter, verify you have battery voltage at the purple wire on the terminal strip...the one going to the amplifier. With the key on. If you do, go to step 2.
2. Turn the key back off, then unbolt and disconnect the coil, then unscrew the whole thing from the distributor cap. Then remount the coil and reconnect to the amplifier. Rig up a spark gap from the end of the coil spark wire to ground.
3. Unplug the black and white wire leading from the amplifier to the timer base. Turn the key back on, and lightly brush the wire across a bare metal grounded part. You should get a flurry of sparks across the spark gap. If you do, you know the amplifier and coil and associated wireing is OK. If you don't get sparks, it is the amplifier or coil.
4. If that all checks out, it is time to pull the flywheel and check the points and distributor.
efreak29
well i tested voltage at black and white wire going to the points and it tested 12v until i hooked it back together then the voltage dropped to 0V and I have a constant 12V going to the amplifier but no voltage on the wire going to the coil and I dont know if its the amplifier or what? but i still need help! Thanks
Big boy
efreak you need to read the post from FR again, I don't think you did the test correctly if you did it as you said in your last reply.
