Hello
I have a question about putting a seal kit in the lower unit. Here are some pictures of my motor and the seal kit I have. Well I hope you can see the pictures. Anyway what I hope to resolve is the drive shaft seal just below the water pump and above the drive shaft bearing. My manual says use a seal puller to remove this seal. But as you can see from the pictures ( I hope) my motor has a brass bushing above the shaft bearing. Also the seal from the kit that is the same diameter as this bushing does not fit the drive shaft. Whats up? do I have the wrong kit? there are two smaller seals that do fit the drive shaft but they are smaller diameter than the area where the brass bushing is. I tried to take good clear picture to show what I mean.
Basically, I just need help in putting a seal kit in my lower unit.
