'71 9.5 Johnson; half max RPM in forward
Bassmast
Turning throttle will achieve maximum RPM in reverse or neutral, but in forward, only about half speed is reached. The engine will occasionally stutter and get to a higher speed for a split second only to go back to a slow speed. Any Ideas? From looking at other messages posted, I'll check out the return spring on the throttle plate shaft but any other suggestions would be appreciated.
JB
Re: '71 9.5 Johnson; half max RPM in forward
Howdy, Bassmaster. I suspect fuel starvation. Tank, hoses, fuel pump are most likely (in reverse order).<br /><br />Good luck.<br />JB
