jamesdswanson
- Joined
- May 20, 2011
- 12
I have a `71 Evinrude 50 hp model number 50173s. I have a service manual and parts catalog for my specific motor. I am in the process of rebuilding the carburetors and when I went to remove the slow speed needle valves it was not a needle valve, it was just a screw with a rubber o-ring. I also have 3 jets per carb that are fixed, with my manual is only showing 2. one being fixed high speed and the slow speed with low speed needle valve. All of the linkage for the slow speed mixture knob on the outside of the motor housing has been removed before I owned it. Are these carbs off another motor? The parts numbers that are stamped in to the carb housing and the float bowl do not match my parts numbers in the catalog. Are these carbs off of another motor? Any help would be appreciated.
