twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
Picked up a 71 Johnson 2 horse that was obviously used very little and has no signs of salt corrosion. I installed a new impeller and the rubber grommet at the top of the pump where the copper pipe attaches. The pump looked good. Anyway, the motor is overheating. The impeller key is in place. It does put out exhaust and mist from the leg holes. The intakes are clean. I took it apart and flushed water up the copper pipe and there does not appear to be any restriction. The only thing I can think of that could be a problem is where the pipe meets with the head. I imagine there is a grommet at the top. Is this a likely candidate? Is there anything that's a common problem with these motors? Anybody familiar with these engines and what the problem could be?
