97fordrunner
Thread starter- Joined
- Jul 10, 2014
- 71
Good afternoon.
First let me preface this by saying i'm fairly new to outboards especially older ones like the one I just got with my '72 Crestliner. When I first got the boat on trade it would idle but thats about it, come to find out the flywheel nut was loose and the flywheel had broken the key way- so i fixed that and got it running better but still not great. I have the OEm manual and have gone over the carb adjustments and Syncing and it does fire right up and idles but when coming off full throttle it sounds like its loading up. Also at WOT its seems like its holding back like it has more RPMs but just cant get 'em. I've been reading thru the forums and thought the timing might be the case but found that the carb/ign timing is extended all the way not allowing me to advance it the 4 deg it is supposed to instead at idle it is directly at TDC if not retarded 1-2 deg.
On another note with the cover on it idles about 200-300 RPM lower than with the cover off. Any ideas on that? it does seem like there is a lot of exhaust under the cover when I pull it off but not sure where it might be coming from, Thank you guys very much in advanced.
