71 Johnson tilt pump
tugsarecool
My tilt pump is finished and I am having problems locating a used one. Any suggestions where to look? The mechanic at the marina says this pump was used on older Chrysler motors as well. It has a manual bypass valve. The motor ia a 71 125hp Johnson
tugsarecool
Re: 71 Johnson tilt pump
Thank you so much for those replies! I found exactly what I needed in about 5 minutes with those links. Kudos!
