Huron Angler
Thread starter- Joined
- Apr 7, 2009
- 6,025
I used the motor last summer and it starts up great, idles fine and will plane my 16' Starcraft out and top speed has been around 29-32mph.
I didn't run the motor too much since I knew it had issues.
After testing compression last night I might be willing to invest some cash to get it running 100%.
The results are as follows...
Cylinder#4-----3-----2----1
Test 1: 105--120--124--125
Test 2 110--122--125--125
(Oiled added to cylinders)
Test 3 124--130--131--130
I was surprised and glad to see that the compression #s were so tightly banded. I fully expected to see horrible results that would make me inclined to start pricing used outboards.
Obviously it would be nicer to have them in the 150 range, but at least they are not all over the board.
I hired a mobile marine mechanic that looked at it and told me that rather than rebuild the carbs, he thinks the wiring harness needs to be replaced first.
The wiring is terrible on the motor, to the point where it's surprising that it runs at all.
I plan on either re-doing all the connections or ordering a new harness altogether.
Some folks have expressed doubts that the electrical issues would cause a motor to lose top end RPMs.
I have a tach on the way so I can get more info on what's happening once I'm finished with a transom rebuild.
The mechanic was pretty cheap($40/hr) so I'm not 100% that he is the best guy to get advice from in this case.
Any thoughts?
Any thoughts?
