71c squeals when engaged
patmilstead
Just replaced oil pump gasket and seal on 71c trans, reinstalled, filled with type A Trans fluid.
when I engage trans forward or reverse it squeals. even at idle this did not happen before changing seal.
Any suggestion out there??
Pat
Capt Ken
Re: 71c squeals when engaged
If you just removed the round pump on the front of the transmission, then the rest of the transmission is undisturbed. Be sure the noise isn't coming from the packing nut. I've also had cutless bearing make noise if the alignment wasn't right.
patmilstead
I disconnected drive no more noise. guess its time to get the feeler gage out.
