Ok, my "story". end of season had only forward gear, couldn't get out of gear. Put in storage. Pulled out of storage and found drain plug must have come out in lake then sat out in cold all winter, gears froze, rust. Pulled lower unit. Got bearing carrier out, cleaned up surface rust. Ordered all seals, o-rings and related parts and a nettle bearing that rusted up. Everything moves freely now. Sooo, a buddy convinced me to just take it ALL apart and replace all the bearings. Which brings me here. I need to remove drive-shaft so i can replace those bearings along with forward gear bearings as well. How can I remove the pinion nut without special tools and how do I set the proper backlash on re-assembly?
Thanks.
Thanks.
