72 7.5 Merc
rnl
O.K. I have fixed may gas leak, and found the correct plugs. I also found and fixed a problem with the throttle linkage. In neutral the engine winds out great, but when I put it in gear it doesn't seem to go like I would expect with the way it revs in neutral. The engine has a plastic prop on it and I was wondering if putting a metal prop on would help?
roscoe
Re: 72 7.5 Merc
Prop should have little to no effect, as long as it fits and is not binding on the gear housing.
rnl
Re: 72 7.5 Merc
:)Thanx. Anyone have any idea what might be wrong? This is on a 12' aluminum boat, I only weigh @ 125, I would expect this to plain out but maybe I'm wrong.
