ATXastro
Thread starter- Joined
- Apr 20, 2017
- 30
Sorry for such a basic topic but I’m unsure of myself, as this is the first outboard I’ve owned. I bought a new fuel tank and a new Evinrude/Johnson fuel line and primer bulb set but can’t get fuel to the fuel pump apparently.
I removed the line that goes to the intake on the fuel pump from the old fitting on the motor and a little gas did come out of the old old fitting upon squeezing the bulb. Re-hooked the line and continued squeezing the bulb but could not get fuel to make it up the line to where it goes into the fuel pump. While this line was off I did blow into it and it was clear so I’m a little confused.
Guy I bought it from assures me that it was in great running order as recently as last fall. Probably a silly question but should you be able to pump gas through the system with the bulb and observe it coming out at any point you choose to remove the line ? Thanks !
