Well, must be time for an update. 4-day weekend (Canada Day), and needless to say I'm sunburnt and exhausted.
I was able to get the stringers tabbed in, a layer of CSM and 1708 for each, on both sides. I added two cross-members (they aren't touching the hull in these photos, until I get the cap back on. I'm not an expert at fiberglass, and there is quite a few areas where I could net get the air out, but it is way better than the factory and once it is foamed I'm sure it will be just fine.
I've used about 9 gallons of resin so far, running low. Used all my chip brushes, cabosil, and acetone. Needless to say supplies are dwindling. I have lots of cloth and matt left, which should more than do for the floor.
I was fortunate today that my father volunteered to be around to assist while we lowered the cap back on (temporarily until the floor is bedded into position).
Wasn't too hard, fit great. Every screw is in the original hole.
The rear spoilers lined up nicely, and should pull right back into place without a problem.
I'll have my work cut out for me to try and repair the splash well skin. It will be a while before I get to that point.
I have a few floor sections to cut, then I'll tab them into hold the hull and remove the cap again.
