jrs_diesel
Thread starter- Joined
- Mar 3, 2010
- 552
I have a 72 Johnson 6 HP long shaft, that came off of my old sailboat. It needed work, so I'm rebuilding it.
In the mean time I had bought a new 6HP for my current sailboat, and it is a long shaft. So I don't have a need for two long shaft engines. I have an inflatable dinghy in need of a short shaft motor, so I thought I would give the Johnson 6 HP a new home
The Johnson looks like an easy conversion, remove the 5" extension, install a shorter driveshaft, shift rod, and cut 5" off of the water tube.
I do not any of the proper tools to cut, weld, and balance the driveshaft, so I want to avoid doing that. Same thing with the shift rod, I don't want to cut and splice it.
Where would be a good source to get the shorter drive shaft and shift rod?
