Chrisravosa36
Thread starter- Joined
- Aug 16, 2015
- 622
Im currently running a 17x14 aluminum prop. I get 33MPH @5350RPM 2.00 Gear Ratio this is a 23% slip rate which I would like to lower. My motor should be at 6000RPM (its a v4 looper this is where top end should be) WHat kind of prop should I go for? 4 bladed SS? 3 Bladed SS? Its a standard rotation motor, the boat is a little wet (less than 100lbs of wet foam in it) just a little in the back gunnels each side. This should do much. Looking for the best MPG cruise speed. Suggestions? will I need a prop with more cup or bite??
Thanks - Chris
Thanks - Chris
