mr300z87
- Joined
- Sep 15, 2010
- 698
Mark
I would have to study the wiring diagram for your engine in order to figure out to rig up the switch it could be as simple as a jumper across the starter relay. But I believe the simplest way would be as mentioned above heavy gauge from Battery + to large lug on stater and from block to - battery. Then 12v to the + side of coil to energize the ignition and then just jumper across the starter 12 V to the solenoid on the starter to spin it over. Oh and I just stuck the fuel inlet hose from the pump in a red gas can as a fuel supply. Hope this helps.
