Kailofsouls
Thread starter- Joined
- Jul 7, 2016
- 35
So I replaced the dual fuel pumps on my motor but I think I might have my check valves backwards I'm not sure. When I run the motor after 2 minutes or so if I don't squeeze the primer bulb the motor will die. Vent is clear, tank is clean, all fuel lines are brand new, new bulb, and inline fuel filter. Carbs are clean, and the levers in Carbs are set. My question is. Does the fuel flow in a loop gas to top pump out to carb 1 to 2 to 3 to bottom pump back to top? Or fuel to top pump to carb 1 AND bottom pump to carb 3? I've attached a picture to try to make it easier to understand what I'm saying. I confuse myself sometimes
