Re: 73 85hp rude Head scratcher
Well I made it to work, at the shop not the office.
Timer base ohmed at 12 ohms. replaced it with a good base ohmed 8.5 on the money.
cleaned, carb bottom one, used that high dollar napa carb cleaner, it is good stuff, better last the next 3 years for the price.
Results.
I have a 7/16 spark on all 4 cylinders, checked with all spark plugs in and using a spark tester, measured to 7/16. The spark is not blue, it is yellow on # 4, blue on #2, blue on #1 and yellow on #3.
I can take the plug wire off while engine is runing and no difference on #4, pull the plug wire off on #2 and the engine stalls and dies. Pull the wire off of #3 and only a slight difference. Pull the wire off of #1 and it barely runs.
I can put my fingers into the throat of the bottom carb and it makes no difference in the way it runs. I put my fingers in the throat of the top carb and it chokes the engine out and dies. fuel is flowing great into the bottom carb as my fingers come out all wet when I put them in the throat and of course can feel it being drawn into the intake, reeds looked good as far as I can tell, can not see the bottom reeds due to angle.
I guess I could swap sensoe #1 and #3 h and swap sensor #2 and #4 to see if I now get blue spark on #3 and #4.
I had a bad timer base high ohm cause weak spark, now it look like one side of my powerpack is weak also?? Only running on top two cylinders?
I can hear it increase in rpm and then decrease, intermittently, sure sounds like ignition.
stator is good or there would be no spark at all.
Is it time for a new powerpack and coils or just order powerpack?
Waiting for replies before starting to throw parts atthis old rude.
thanks for all the help
