I have a 73 Evinrude 115 and I've noticed that when I'm sitting still idling and also after I shut the motor off, there is gas and or oil in the water around the motor. I can't see anything obvious that is leaking and actually the motor seems to be running really well. It can take a little longer to get it started when it's cold but I've found that if I pull the plugs and clean them, it starts quicker. And when I pull the plugs, they're always wet. I rebuilt the carbs about a year ago and set the floats to parallel with the bodies. Cleaned everything to the best of my ability.
Again, I hate to mess with it too much since it's running so well but it appears I need to. Any suggestions?
As always, thanks for your help!
