73 evinrude 6 h.p. gas/oil mixture?
merkdawg
Just want to ask if the gas/oil mix is 50:1 on this engine? Thanks
Rick.
Re: 73 evinrude 6 h.p. gas/oil mixture?
it sure is. Best of luck. Rick.
merkdawg
thanks? what about plugs? says on the tiller handle j6c, but that has been changed to j6j parts place said they don't make a j6j anymore.j8j? will that be ok?
1oldmaster
Champion J6J was the original plug number. The new Champion number is J6C, (most places stock it as Champion #823). Most auto parts stores either have, or can get them, for about $2 each. Original gap is .030" for normal use, if you'll be trolling you might want to increase the gap to .035" to reduce oil fouling.
merkdawg
hey thanks, must have got my numbers switched around. I'll get new plugs tomorrow.
