MikeSlater
Thread starter- Joined
- Jan 3, 2002
- 8
Got a question regarding my 73 evinrude 85 hp outboard. I bought the boat used to find that it shifted fine into forward but would only click going into reverse. A new shift cable was included in the boat so I installed it and adjusted it to the condition its in now. I does go into reverse & forward no problem (with a little assistance) The way its adjusted neutral is pefect and it will barely click in to gear with the motor off (reverse and forward) It seems if the lever would move 1/4 inch into both gears that it would be fine! I guess it doesnt have enough travel in the controll to make it happen, all though once you are at about 1/2 throttle the lever is moved further. It is a morse controll circa early 70's with no adjustments that I can find other that the cable swivel. So im in a bind here as far as what to try, I would like a single lever dual control but I was thinking I could get a dual lever single control, use one for throttle and the other for shifting. I think they are adjustable as far as stops and such. That way I can have full travel control over shifting with no throttling up. Dont know just a idea. I did manage to fix the trim motor lowering problem with a good motor cleaning and fluid top off. I read in another post about the o-ring on manual release valve busting. I also busted mine and was unable to find a genuine part as they arent made anymore. But I did find a perfect replacement at home depot in the plumbing dept. Works PERFECTLY! I bought 5 of them (34 cents each!) I can get the exact size in daylight if needed. Thanks!
