erniex
- Joined
- May 26, 2004
- 93
Pulled LU to replace water pump, check seals etc. I was checking the shifting from F - N - R by operating the lower shift shaft with a socket wrench. The unit clicks and locks solidly into forward and reverse, however when I shift it out of forward into neutral I am still getting some gear contact in what should be neutral (midway between F & R). Only when I start shifting to reverse do I get true neutral (no gear contact)right before it shifts but it doesn't hold. If I release the shaft at this point before it snaps into reverse, it doesn't stay and the spring action pushes it back to the midway neutral position and I have gear contact. I don't think this is correct and don't want to reinstall the LU until I'm sure it's right. Any thoughts or comments will be greatly appreciated. Thanks in advance.
