73 merc 850
muleskinner300wm
Is there a date range and horse power range of interchangeable powerhead parts? (Starter, Carburators, etc.) For my 73 Mercury 850
rtpassini
Re: 73 merc 850
is there a specific reason? what are you looking for?
Chris1956
Honorary Supreme Mariner
Re: 73 merc 850
Mule, Over the years things evolved within the merc inline series. On your particular motor, the starter will not interchange with the later inlines. The carbs are different, but will swap, as will the rectifier and coil. The switchbox interchanges with any 70s model with battery CDI. The gearcase, midsection, transom clamp, cowl support, cowling interchange with may 4 + 6 cylinder inlines.
Specific questions are more accureately answered.
electricjohn
Re: 73 merc 850
That motor started out as a 80 hp in the 1960's and eventually became the 85 in 1973. That 66.6 cubic inch block had a long lifespan. The 65 hp engine of that era was also 66.6 CI.
muleskinner300wm
Re: 73 merc 850
I know that parts might be had to come by. The motor runs but everything looks stock and old. I might find a later model of motor that I can use the parts from.
muleskinner300wm
Re: 73 merc 850
So do you think I could update the motor with parts from a later model 66.6?
muleskinner300wm
Re: 73 merc 850
Thanks, The other problem is that the bottom carb leaks gas like a siv when running. I think it might need a simple adjustment, any thoughts?
Chris1956
Re: 73 merc 850
Rebuild kits for the carbs are available. Get a new needle seat and gasket kit. Check the carb floats for deterioation (foam float) or cracking (Hard plastic float), and replace float if it shows signs.
