GSPLures
Thread starter- Joined
- Sep 3, 2019
- 564
I think I sent the PM not sure though it was acting funny.
As far as foam and draining goes, I was planning on using ridged Styrofoam, like goes on outside concrete basements below grade. Cut it to fit, leave an inch or so space next to stringers and next to hull with spacers. Probably pl it to the spacers which will be pl'ed to the floor. That way any water can drain freely, with drian holes cut in bulkheads and stringers so water can drain back to the bilge. Would that work do you think?
I have been thinking about that, but not sure if i want to give up the extra structural benefit of pour in foam.
Yes there is that, I'm just going to put in a few extra bulkheads for floor support and have the Styrofoam up as tight to the floor as I can get it, maybe a little higher then the stringers and then press it down with the floor itself.
I too mulled over the whole drainage topic. For months it seems. In the end, I decided that the structural integrity of pour in foam far outweighed overthinking a drainage system that should never get used. When the engineers design a boat, that foam goes into the overall concept. Not only does it add some floatation in smaller boats, but it’s necessary structure in boats over 20’. The manufacturers were NOT required to add pour in foam to boats over 20’, so why did they? Strength and rigidity to help support the stringer system.
I decided to focus my efforts on ensuring those cavities that would contain foam were perfectly sealed up. I ensured there were no penetrations into those cavities.
That’s my opinion.....but as a disclaimer, I did not stay at a Holiday Inn Express last night.![]()
