73 Sea Ray restoration
GSPLures
I haven't done a whole lot of work this weekend. My wife's uncle came over yesterday and we picked up a majority of the ply and some of the other materials i needed. I still have to pick up the fiberglass materials hopefully today or tomorrow.
We did get the first layer of the transom cut and fitted.
emoney
That's a gratifying step for sure. Keep plugging away, you'll be on the water one day and so rightfully proud of your hard work!
GSPLures
It definitely is! The smell of fresh cut wood opposed to rotting wood is great.
GSPLures
Its going to be another slow day. It's hot out and no circulation in the garage. I shaved a few spots on the transom wood to get it to sit a little nicer. I'm going to try to get it all cut then use PL to bond the 2 pieces today. I plan on picking up my fiberglass stuff tomorrow. Found a place a few miles from my house. It's more expensive then US Composits but for no delivery wait times and the convenience of being close is worth the few bucks.
GSPLures
Update of today's work routers make work alot easier if all goes well the transom will be glassed in this week and I'll be moving on to the stringers
20200824_142946_compress72.jpg20200824_161939_compress46.jpg20200824_175508_compress96.jpg
GSPLures
I have read alot of back and forth about bonding the transom to the hull with PL. I know using peanut butter is the ideal choice.
Due to it just being me putting the transom in with no help the extended work time of PL seems like a better choice to get it in place and clamp
Is there anything wrong with using PL for this I have read people will only use it to people will never use it and has me conflicted?
kcassells
Yea pl can duck up your day and it certtainly has applications. Its all about the gassing off that messes up your glass and the time you have to wait. Waiting depends on conditions. I used it on my transom for something, not the whole thing and the glass seem to take forever not to bubble up. Still regret using it.
Oh yea back to having to install the piggy by yourself, I actually drilled cabinet handles on the oink oink so I could lift it easier. Filled later and glassed.
GSPLures
The waiting will suck. I was planning on spreading it with a trowel setting in place then clamping. My main concern with using peanut butter is it curing before I can get it fully clamped. I am using 2x4s with threaded rod for my clamps so the getting in and out of the boat is going to eat all my time up. I do plan on doing test runs to see what the actual time it will take
kcassells
Oh my.............You will regret the pl.........promise. You will lose a week or 2 till its gassed assed off. Plus making a fillet is impossible.
GSPLures
I will heed your warning. I will just wait to set it until I can get a helping hand and use resin
kcassells
By the way.........I'm the stupid people!! Good call.
OIP.GSHm0vkJLNXZ-MQ43wu2lQAAAA
kcassells
You do understand that as you make the transom with pb you can screw the shiiit out of it or clamp it. Then let that set until cured.
Next after its set up you install it with the pb. Right?
Grease the rods with something so the pb doesn't stick to them.
GSPLures
Yes. My plan was to make clamps like Frisco boater did with 3 or 4 2x4s on each side with threaded rod squeezing them together through the keyhole. I am planning to make PB with poly resin cabosil and 1/4 chop strand. trowel onto the backside of the transom wood and then place and clamp.
I still have to encapsulate the transom wood in CSM (plans for tomorrow)
kcassells
Thats right on the money! Cool. You'll do fine. Pics will be hard whereas you'll be sweating your potatoes off and have sticky hands. Be ready to remove or fillet the squeeze out. A little babysitting required.
kcassells
So if you get a buddy to help you lift and place the transom definitely do a dry run.
GSPLures
Picked up some fiberglass supplies today.
5gal laminating poly
hardener
Fiberglass Roller
Cabosil
10yds 50" 1.5oz CSM
10yds 50" 1708
Still have to get some foam rollers, sissors, mixing cups, and chip brushes then I will be well on my way to getting some work done!
GSPLures
I am considering dealing with the drain hole on my transom like Frisco boater did, notch the transom above the drain hole and use a small section of pvc pipe then use PB around it. My original transom had a hole through the transom.
Is there any reason why I should not do this? Or is there a better way to have the water go through the transom wood?
