74 Chrysler 15hp torque specs
joho5
anyone have the torque specs for the cylinder head and flywheel nut for this motor.
Im sure it was the same for alot of the motors this size 9.6-about 15hp and a wide year range.
if you have a different year about the same hp, respond as well.
thanks
Matt
eurolarva
Re: 74 Chrysler 15hp torque specs
Year does matter
Cylinder head bolts
1968-1976 120 inch lbs
1977-79 125 inch lbs
1980 on 130 inch lb
Flywheel nut 45 to 50 foot lb
There is a note on the flywheel nut . Torque auto electric armature bolt to 25 ft lb
joho5
thanks man...much appreciated.
Matt
