ok checked the carb holly 2 barrel cleaned it looks like new replaced fuel pump with electric when the motor warms up to 170-180 deg f you can see it drop to 160 seems like the thermostat opens no over heat trouble but just loses power and acts like it has a massive vacume leak is fine cold power metering screws adjust well but when its warmed up cant do more than idle back to shore if i am lucky has 600 hours on motor no smoke tick runs smooth could it be a faulty pcv valve or ??? please help
