Couple people on Facebook have asked how i stripped the boat. There is broken info so i put the process in one response.. here it is.
Here was my process, I used citristrip stripping paste, apply generously with a brush. Wait 2 hours or check with your fingernail to see if its lifting the paint, if necessary wait longer. Do sections, dont do the entire boat at once, do small sections. The paste will dry out if you let it sit too long. if necessary wait longer. Use a power washer(3500 psi minimum) to blast the paint off with the 10 degree tip starting from the bottom of each section and working toward the top. I had to blast the metal at point blank range on many parts of the boat because the paint was soft but still adheard to the boat(would have not come off with a scraper). When i finished stripping it I had to repeat the process again because like i said some parts of the paint were really on there(2 layers of paint on my boat). After 2 applications of stripper and power washing it 2 times to remove the lifted paint it. I had to do a touch up application of the stripper on several a few areas to get it to the point where there was only a cloudy film on the boat but it was down to bare metal. I did about 10 hrs of power washing on my boat to get it fully stripped. It was a lot of work. Lastly i took a quart of acetone and an old towel and cleaned the cloudy film off of the aluminum. Wet the towel with acetone and use the wet part of the towel to clean small sections working your way around the boat. Lots of elbow grease during this step as well but that is what gave it that really clean look. Obviously I have a different boat and who knows what paint you have on there but i think the power washer and the citristrip together were a good team.
