'74 Inline six fuel connector issue
testmoron
Has this quick connect fitting where the hose goes into the unit been the source of fuel restriction?I have the 150 and I don't think that little hole can flow near enough fuel.Should I run three eighths hose straight to the pump?
corm
Re: '74 Inline six fuel connector issue
Hi,
They work fine with the connector and 5/16" hose up to 6500 RPM.
Max RPM is 5800. so don't worry about it.
j_martin
The genuine Mercury (metal) connectors work fine. At higher horsepowers, the aftermarket (plastic) connectors will let you down.
hope it helps
John
