74 lower unit trouble
trey3670
ok heres what I got a 74 70ho evinrude with a bad lower unit,it apears the thrust washer on the drive shaft let go and knocked a whole through the worm gear case. then the fragments got into the hydraulic pump and did a number on that.
so what I would like to know is where to get another lower unit? or maybe just the pump I have a welder freind that thinks he can fill the hole in the case.
what other years fit this power head? can I put another lower unit on it that does not have this kind of setup?
thanks guys.
ezeke
Re: 74 lower unit trouble
You should have very little trouble in finding a good used matching unit at one of the many salvage yards. I think, from my experience, that the units were very good.
Try some of these companies:
sea-way. Com
outboard-parts. Com
marinepartsoutlet. Com
laingsoutboards. Com
tcoutboard. Com
fairwindsmarina. com
salvagemarine. com
HighTrim
If you do happen to try repairing the lu for whatever reason, try TIG welding it with Argon
