'75 6hp johnson seahorse; water in cylinder?
fishmano
Lost power while on the lake, but putted back to launch on one cylinder. Got it home checked plugs and found water on lower cylinder. Checked compression and 0 on same cylinder. Other than head gasket are there other possible entries? Is it possible to buy just the head gasket or will I have to buy whole gasket set?<br />Also after removing head, I can see some minor scoring on this cylinder, any thought here (time for rebuild)?<br />Thanks,<br />P.S. Great board tnx iboats
fishmano
Re: '75 6hp johnson seahorse; water in cylinder?
Anyone? Would like to get started asap!!!<br />Thanks again,<br />fishmano
D
DJ
Guest
fishmano,<br /><br />Since you have a scored cyl., it's tear down time.<br /><br />Once you do that, you'll probaly find the source of your leak-most likely a head gasket.<br /><br />Don't forget to change the water pump (impeller).
fishmano
That's what I was afraid of. <br />Thanks for the reply<br />fishmano<br /><br />"Bent rods and tight lines"
