Barnacle_Bill
Thread starter- Joined
- Feb 8, 2004
- 6,469
I have a new to me 1995 Merc 75HP. While out running WOT the motor suddenly acted like I was slowly throttling back and died. Primer bulb checked good. The motor started right back up and idled good but would die when I tried to give it gas. It did this several times and then started to act better. I took it back up to WOT and it acted like it was going to die again so I throttled back a little and it ran ok the rest of the way in.
Inspection didn't show much. No loose connections. All fuel hoses and bulb good. No loose linkage. I did find the arm from the trigger loose to the point it rattles but appears to be working fine. I found an inline filter and replaced it but don't think it was causing a problem. Since I don't know the history of the motor I'm going to rebuild the fuel pump. Am I forgetting anything?
