ShaneB23
Thread starter- Joined
- Aug 23, 2017
- 13
Hello Everyone! This is going to be a long winded explanation/ask for help/confirmation.
Took the boat out for a test drive before I bought it. Fired right up and had no problems. Put it in the water myself and being an amateur and not having been around a boat since I was probably 10-12 with my Grandad when he was still around, forgot a lot of important things. My stupidity happened as follows:
-Puts boat in water
-Puts bumpers/buoys outside of the boat and ties off to dock.
-Puts tilt pin in to support motor.
-Turns key several times playing with throttle and engine won't turn over.... (did this for about 10 minutes before realizing the following)
-> I've realized now that I've A) not put the engine in neutral and B)Forgotten to pump the fuel line until the rubber ball is hard. (I did however remember to make sure the air-intake slot into the gastank was open).
-I finally do the above and I get the motor running. (Of course by now it's getting dark and I don't want to go out god forbid the engine doesn't want to KEEP running as I don't know it that well and have only had the boat since Monday)
TO THE POINT:
I put my flush muffs on it in the driveway on Wednesday night and it tried to start the motor after following the appropriate steps to do so. It tried the first time to turn it over and then it started sound sadder and sadder. Naturally as it sounded like it progressively dying, I thought it was the battery(Brand new batter with high CCA's btw). I Tried Jumping the battery from my truck and it didn't help at all. Was thinking maybe I wasn't getting good contact from the jump...
Took the battery to work the next day and used the battery charger. Went home cleaned/polished every single contact on all of the wiring just in case I was getting some flow resistance from that, given the age of the engine... Hooked the battery back up and tried again... Same deal first couple times the starter would start to spin (*slowly) and the gear would go up and engage and try to turn and it would stop. Couple times trying this and then the starter just buzzes now when I turn the key.
I've ruled out the battery, I've cleaned and polished all of the contacts, I've cleaned the spark plugs. I'm thinking the starter (Original one from the motor) is shot from my overworking it the first night I put it in the water and made a stupid. Can anyone confirm before I pay the $350 for the new starter?
Thanks everyone!
-Puts boat in water
TO THE POINT:
Thanks everyone!
