75hp evinrude putting out 16 volts
sutor623
Model is e75tlcrd. 1984 75hp. The voltage at plain batter is 12.6 or so. Under throttle the vtage goes up to about 16 v or so. Is this normal? Do these motors have voltage regulators?
eavega
Re: 75hp evinrude putting out 16 volts
I don't know about your model, but I had a 1976 70 HP that was unregulated. Voltage could get upwards of 17 V if on an extended WOT run. My solution was to have high-drain devices running while going full-bore. Usually having my phone charging and the GPS powering up via power ports coupled with a humongous battery kept the voltage under 16 V.
Rgds
E
sutor623
Gotcha. Thanks for the reply bud. I'm pretty sure there is no regulator on this guy. I just bought a $1300 GPS combo unit and do NOT want to fry it. Do you think that I should just get a separate battery for the high dollar electronics?
boobie
16 volts or higher is normal on those systems as they are unregulated. Like you said, a seperate battery for your electronics and then charge it when you get home.
sutor623
Cool thanks Bob as always! How you doin bud?
sutor623
Glad to hear it. Thanks for all your help with the shift shaft seal. I left the motor tilted all night and it didn't leak a drop!
boobie
You're more than welcome.
Crosbyman
if your electronics don't draw to many amps you can get **** flat 12volts from a couple of Radio Shack 12 volts regulator chips hooked up in paralell* to increase available amps (each chip will give 1 amp of current ) . My humminbird Paramount WIDE fish finder would shut down on high voltage peaks from my Classic 45 merc.
*(2 same pins to ground...2 same pins to Batt+ ....and 2 same pins Flat +12V) mounted on a piece of aluminum with heat sink
silicone)
The small regulators (2) were hooked up in parallel and no more shut downs
The chips can handle anything from +12 to +35 V DC and put out a flat 12V (1 amp each)
Hook up the BATT + via an accessory switch to turn off the regulators when not in use.
