Re: 75hp Mer OpiMax vs. 75hp E-Tec
Why not add a 6-71 type blower and burn nitrous oxide; or ether, castor oil, and alcohol? Man, talk about power. However, it's doubtful it'd run all day rigged like that, which is what an outboard is expected to do.
Typically, on a given engine, when output is increased, dependability is decreased. With outboards it's a fragile balance. If your car quits, you pull off of the road; if your outboard quits, just hope the currents don't carry you to Cuba.
... with todays turbos there is no lag and you gain ALOT of power for very little added weight (would be a better setup than the Mercury Verado IMO).
