I am new to the forum and new to owning a boat. I bought an old 1980 Bumblebee 15.5 ft fishing boat from a guy that has a 1980 Johnson 75HP Stinger on it. I have found this forum to be a great help as I have been trouble shooting several things on the boat. I thought I had them all fixed and good, got up with my son this morning at 4 to go out fishing, got to the lake, put the boat in and the motor turned over but wouldn't start. I tried for about 10 minutes and then it wouldn't even turn over. I figured it was a dead battery but wasn't sure. My son's face killed me when I said we had to head back home. He kept saying maybe it will work if we get it out in the middle of the lake.
So I get it home and the batteries are fine, and now I have no idea what it is or where to look.
A little bit of background on what I have done so far, if any of it is wrong please let me know and I will fix it. The first problem was the trim wouldn't work for some reason, the guy I bought from said the wiring harness was bad (which it was) but that was it, and it was wired through 1 solenoid. I researched here and on google and found a good diagram showing using 2 (one for up and one for down). So I rewired it all and still couldn't get it to work. So as I was test it with a multimeter I noticed that the only time the blue and green wires were having power ran through them was when they were pressed. So I straight wired it, works like a champ now. At the same time I remove the solenoids thinking that was all they were used for. Now I am guessing that the solenoid was need to start the motor? Not sure? SO I am trying to figure out or find a wiring diagram, that would show how the wires from the ignition make it to the motor. I saw the basic wiring diagram but it didn't really show that. Any and all help would be appreciated.
