mlbinseattle
Thread starter- Joined
- Aug 1, 2015
- 100
History:
Checked compression (110, 105, 105, 110 psi). Installed new plugs. Rebuilt the carbs and triple checked everything. Replaced the cylinder cover gasket because of leaks, replaced the transfer port cover plates' gaskets (gaskets so old, bolts became loose, and it was losing gas mixture), and replaced bottom crank cap seals (These were shot.) Cleaned all electrical connections, installed new gas lines, new checkvalves/diaphragm/gaskets for fuel pump, and installed water pump kit in lower unit. Rings appear to have tension (spring), but I did notice some scoring on the piston sides. I'm assuming previous owner let the boat sit for several years, and the rings seized causing the scoring. In any case, I believe there is some life left in the block. I checked spark by removing plugs, leaving those connected to the plug wires, and grounding all those to the engine ground. Got a nice blue spark on each one, so I thought the spark was okay.
Prior to/after startup:
Ensured fresh gas with 50:1 mix and added some Stabil per instructions. Engine will start with some difficulty. It will also restart with some difficulty. I initially adjusted the idle adjust screws on the carbs for 1 turn out. After running it, these are now somewhere around 1.5 turns out (I don't remember exactly). Static timing while cranking was set for 2-4 degrees BTDC. Haven't adjusted static timing for WOT, yet.
It appeared that it was running okay after I made the initial carb adjustments, or so I thought. Then, on each time it has ran, I would turn the idle adjust screw in a little more (lean) to see if I could get it running even smoother and find the sweet spot. At this time, it seemed like the engine would jump in RPM and sound really good. This was a jump. No stumbling or anything like that. It would immediately jump. What I thought was good, before, apparently was a miss in the engine. When this happened (increase in RPM and sound really good), the engine would run for a few seconds, then die.
I pulled the plugs, and it looks like those were beginning to foul. I cleaned the plugs, re-installed, and got the same results. It seems like it was actually easier to restart the engine after cleaning the plugs than before (not doing anything with the plugs). In my mind, not all the fuel was getting burnt, but I'm sure some of it was probably due to the rings. Still, it shouldn't be fouling that quickly. To me, it appeared the plugs weren't burning as hot as needed to be.
One more time, I removed all the plugs, left those connected to the plug wires, and grounded all the plugs to look at the spark, again. This time, I noticed that there was intermittent spark on a few of the cylinders. Seems like those were firing every other time instead of every time. And sometimes, they'd fire each time although, most times, they wouldn't.
That's when I decided to inspect the ignition system. Made myself a DVA adaptor to take DVA readings, and here are the results:
Stator (I'm sure I have the black OEM stator and not the CDI stator)
Red to Red/White - Approx 23 VDC (Spec calls for 25 - 100VDC.) Ohms: 68 ohms (Spec calls for 125-155 ohms.)
Blue to Blue/White - Approx 113 - 115 VDC (Spec calls for 180 - 400VDC.) Ohms: 7100 ohms (Spec calls for 5000-7000 ohms.)
The above voltage readings appeared the same with the wires disconnected or connected to the pack.
Trigger
Brown to White/Black - Approx 2.3 VDC (Spec calls for 4VDC) Ohms: 863 ohms (Spec calls for 800-1400 ohms.)
Purple to White - Same as Brown to White/Black
I haven't tested the pack, yet (haven't found a procedure, yet, for checking it). From what I can tell though, I'm assuming it's good ... for now.
Conclusions:
From what I gather, it appears that the pulse going to the pack from the stator isn't sufficient to generate a charge great enough to send the proper spark to the plug. This could explain why the plugs aren't burning all the fuel. Additionally, the trigger pulse appeared much lower than what it needed to be. This could explain the intermittent firing of the plugs(?).
I'm aware that fuel issues and ignition issues can result in almost the same symptoms; however, I have done my best to rule out gas issues. Like I said, before, when I turned the idle adjust screws in slightly from 1.5 back to 1 turn out while it was running, it appeared that there was a delay of a couple of seconds, then the engine would jump in RPM and run great. My thinking is that the fuel was leaned out enough for the weak spark to burn all the fuel.
I'd like to hear what you experts think about all this. I'm about ready to take a sledgehammer to this thing as I've already spent a sufficient amount of money, and it looks like I'm getting to spend some more.
Trigger
Conclusions:
