Re: 76 9.9 wont start any help guys
first fix the pull starter,you might be best to just order a new spring,BE CAREFUL,those things are dangerous,you can search for instructions on installing a spring ,its not that hard,more danger than hard,as for starting,if your not getting a GOOD PULL on the flywheel,it may be thats the probllem,not generating a good spark,but ,also check the wiring to the kill button,if it looks OK,disconnect the button ,try starting,the buttons go bad preventing spark
