jafitzwater
Thread starter- Joined
- Jun 10, 2013
- 37
1976 85hp evinrude
I'm having a big problem here.
The story;
I purchased the boat with this motor and when I took it out it shifted and ran great propelled the boat to 45mph.
After a handful of times taking it out one day when trying to throttle up the boat wouldn't go fast it felt like it was bogging down.
I changed the gear oil and it was black as night so I assumed that could be the issue. After doing that I tried to shift and spin the prop since it seemed like it wasn't completely engaged and when putting it into gear the forward would slip until I manually pushed the linkage forward then it would engage.
I did the test to see if it could have been the lower end and when removing the plugs and putting in gear by hand then spinning the flywheel it moves the prop. Also when moving the prop when manually doing the shifting it locks the prop from spinning in forward and reverse then freely in neutral.
After I put it all together then adjusted the cables to where it shifts properly I took it to the lake and put it in gear and it still does the same thing!
What is going on??
Please help
Thx
The story;
What is going on??
Please help
Thx
