52FordF2
Thread starter- Joined
- May 31, 2013
- 372
There is a lot of pitting on the top of tank. I can find at least three pin holes to repair. I'll be sandblasting all pitting before I repair it.
Here the plan:
1. Clean Tank inside and out.
2. Sandblast all pitting, will probably open a few more holes up.
3. Use the Aluminum rod to fill holes and imperfections.
4. Pressure test at 5 psi for at least a week.
5. Use POR15 inside the tank to seal it more.
6. Metal prep and paint tank.
JB, Here is a few test or practise pieces.The rod worked OK. It may be because I do a little welding or soldering at work.
The #1 piece I used rods that I got from an Auto Swap Meet I attended. The #2 piece the rods came from HF.
Here is what I did,
1. Cleaned the surface of each piece.
2. wired brushed it also.
3. Started heating the surface, when the rods started to smear like solder I covered the holes.If you push the rod into the hole at the same time it ouzes out the other side a little.
I liked the HF rods better than the Swap Meets
It seams to grind OK also.
Hopefully I can get to sandblasting tommorrow?? I found out that somehow my sand got wet. Am now trying to dry it out.
Here the plan:
Here is what I did,
