I recently purchased a 76 Johnson 25 Hp model 25EL76E. Electric start.
I ran the motor several times ran great. On the fourth trip out I could barely
get 1/5 speed. Checked the linkage OK. I have checked the linkage,prop,sheer
pin repeatedly,plugs.
Here is the situation. If I run in a barrel in neutral manually moving the
throttling it wants to take off !! When out on the water in forward 1/5 speed
at best. Checked the sheer pin and prop OK. The engine is not roaring like
in neutral. I had the cover off to see that the throttle control was fully forward. No roar runs very slow ?
Doesn't make any sense to me. Any help would be appreciated.
