'76 Johnson 25hp fuel re-circulating hose?
oldcatamount
Where does the small hose coming from the upper by-pass cover go to?
There isn't any place (that I can find) to connect the other end and my parts diagrahm is vague.
bktheking
Re: '76 Johnson 25hp fuel re-circulating hose?
Upper crank bearing?
oldcatamount
The upper crank bearing has a larger diameter nipple/hose and that hose leads down to the lower part of the intake manifold. The one that comes out of the upper by-pass cover is quite small, less than 1/8 I.D and it heads toward the carb or the intake manifold and I don't see a nipple anywhere in that area. I wonder if it's OK to let that little hose dangle?
Daviet
The parts breakdown calls it a " hose manifold to cover".
oldcatamount
Where did yo see the parts breakdown? I've had a heck of a time finding one.
oldcatamount
Thanks for the link! :)
Daviet
Your'e welcome, hope it helps.
