Hiya,
Long time since my last post... I'm finally thinking I should get around to fixin' up my ole 6 hp... as per subject line it's a 1976, been in the family since new. I took it out of commission 2 years ago... it idles fine, compression is good, ignition is good... but at 1/2 throttle and above, it only runs on the upper cylinder, and the lower plug has water droplets on it after running above 1/2 throttle. Thinking it might be a leaky head gasket, I replaced that, but it was not the problem. The other suggestion made to me way back when was that it could be a leaking exhaust gasket, under the block-side exhaust cover letting water in to the bottom jug that way. I do have the factory service manual, but there are no instructions for R/R that cover or gasket. As far as I remember, what I should do is pull of that rectangular cover held on to the port side of the motor by slotted machine screws, inspect, and possibly replace whatever gasket is under there... sound right?
Here are some Q's:
I guess the power head needs to come off for this? Seems like it would be a nearly impossible job otherwise. There wouldn't be enough room to get an impact driver or screw driver on the lower screws.
If the power head needs to come off, I guess I'd also need a new exhaust gasket (if that's what it's called?), the sits below the motor. I haven't looked lately, but I guess the factory manual should have a section on powerhead removal.
Do the symptoms I'm having fit with a leaky gasket under the exhaust cover under the motor? I think (?) the problems may have started following an impeller replacement. It pumped WAY more water afterwards, so I'm thinking the water pressure throughout the motor likely went up quite a bit.
Would be nice to get this working well again... it's a nice little pusher for the next generation of kids to learn on.
Thanks for your $.02
Here are some Q's:
