- Joined
- Jul 23, 2011
- 52,083
as mentioned above..... NO. its the opposite. the points are what open and close to energize the coil primary side, then allow the magnetic field to collapse allowing the secondary side to fire.Not yet. I just took the wire off the distributor and held it near the block while cranking the motor. No spark at all. Wouldn't servicing the points come after getting the coil to spark? I don't know if I mentioned this boat is new to me.
without servicing the points, is expecting a toaster to work when its not plugged in.
with points..... run a points file thru the contacts (or your wife's nail file). rough gap to 0.016, use a dwell meter to set dwell, then set timing.
