'77 140 V4 - High Performance fuel pump?
Johnson 140
Will it hurt anything to use a "high performance" fuel pump on a '77 140 Hp V4? I ordered a fuel pump for my engine model # (140TL77S) and received the high performance version.... Noticed the gasket from the screen filter cover to the pump was different and then looked at a PDF repair manual (covers 73-89 models) and it only referenced the hp pump for V6 models....
emdsapmgr
Re: '77 140 V4 - High Performance fuel pump?
Not sure what part number pump you received and how you determined that it is a "high performance" pump. Is it a Bombardier pump? What part number? Hard to really veryfy anything unless you are working with a factory service manual. The generic manuals just don't measure up. The original 388268 pump was designed to run the larger 115/140 engines in 1977. There is a long line of supercession (5) part numbers on this pump. The early supercessions probably involved changing to rubber parts that were not affected by the newer ethanol fuels. Today's equivalent factory part is 438556, about $100. None of the older V6 pumps supercede to the same part number as the current 140 hp replacement pump. I'd be careful using that pump if it is a V6 pump. The older V6 engines used two of those pumps, and they are not the same part number. Possible one of those pumps is a lift pump, the second is the pressure pump. Not sure that either one would make a good subsitute for a single pump application. One of the other experts on this board may be able to chime in and fill in additional details. You can check out the original factory parts lists online at: epc.brp.com. It is handy for determining what replacement parts you need and is useful when making repairs also.
Johnson 140
P/N 18-7352 (replaces 0438556) - marineengine.com lists these p/n's for my model......fuel pumps.jpg
There is a slight difference in the shape of the top of the housing and the gasket (screen filter side) is different - cap and screen are the same. The mounting gasket and holes are also the same on the new pump and my existing pump.
Johnson 140
I have ordered the service manual for my engine. In the meantime, the generic manual states that the 'high performance' pump can accomodate more vaporized fuel in the line - minimizing the chance of running the outboard with low fuel flow...
SparkieBoat
sounds like that is the right fuel pump to me.
Johnson 140
I appreciate the help, great forum! Im going to install the pump I received this afternoon...
emdsapmgr
It is likely that the pumps have changed configuration over the years. Not unusual to have product improvements in replacement parts on something from 1977. As long as you have the correct part number equivalent, you should be ok.
