g0nef1sshn
- Joined
- Feb 24, 2015
- 1,291
If the bow light has 1 black and one white wire, which is power and ground?
White goes to the top of the bulb.
Power feeds the center of the socket which matches to the nubbin on the center of the bulb. The outer part of the socket is ground. Always!
So looking into it, im needing a deep cycle agm marine battery, Do you guys break bank for the high cost ones or can you get away with low cost ones? tell me what ya got and use for your trollers and accessories!
Cranking battery will come when I get a motor.
Why are you letting work get in the way of boat building?
Oh, you still need a motor.Any luck on that front?
I've used all different brands of deep cycle batteries over the years and have NONE of them stand out in my mind as being better than the other, including WalMart batteries. I used the group 27 for my trolling motor and 24 for the start.
