Just popping in to catch up, you're making great progress, the boat looks fantastic!
Thanks Dozer. Thats stuff does get on the loose some times. I only intended to have a bead of it there just to clean up where the aluminum met.
I use philips screws to attach the seats to a swivel base, then bolts to mount the swivel and seat to a bench base. No clearance problems between the two for full 360deg swing.
Bench and seat setup looks good.
I would for sure install a float switch for the bilge with a manual switch too.
Live well works for a built in beer / drink cooler.
1 - running lights
2 - bilge pump, if trailered a manual will work, add auto for extra security if emergency happens.
3 - fish / depth finder, provides lots of useful info while boating
4 - trolling motor - get you home or to safety in emergencies, great for fishing
5 - interior lighting
6 - tunes
Livewell would be 3.5 on the list.
wiring for phone charging, gps
bimini top
Drink could be soda, water, lemonade or any other beverage of choice. I would hope they would revoke any boater license. :watermelon:
same pump or one of each you think?
2 seasons with my Chief and 3 with my SN and I haven't turned either's pump on other than to test them. Not sure I could be convinced I need a couple more pumps.
