77 25hp evinrude
Larry Glady
hey all i have a 25hp rude lower 1/2 way apart with seals in shop but can't figurewhere some seals go part#321787 has me searching, kit from sierra18-2684 seal prop shaft seloc not much help waiting for real manual thanx for anyhelp!!
dew2
Re: 77 25hp evinrude
Prop shaft seals go in the gearcase head assembly,If thats what your asking.Is it? If it is I need those seals for a 75 and can go by this number to help find mine.
Larry Glady
seals in the kitread as n182031 oem cant see where they go there is 2 in the kit i got
Larry Glady
got my manual today still dont see where seal r supposed to go
Larry Glady
thanx but no hidef,got those in kit and know where there go, these new seals read oem n182031 on them sounds like prop shaft seal but cant find them on any diagram thanx for lookin!!
dew2
In that link above look at part #25 gearcase head assembly look inside it they go in it.I have read here of others replacing them,to remove them a dremmel hispeed grinding tool was used.
My problem is I cant find the seals,It was said a auto store NAPA I think has them.
Larry Glady
dew2 they came in a kit 18-2684 on seal reads oem182031 cross ref-321787 i got 2 in the kit and still dont see where they go there was 2 in the kit
dew2
Thanks for the part number! Ok number 25 in this schematic I am putting up is the (P/N 0389045) GCASE HEAD&SEAL AY ... The two seals you speak of go inside they seal the prop shaft the inner seals the grease from coming out and the outer seal seals the water from entering,Double seal
http://www.crowleymarine.com/johnson-evinrude/parts/40884.cfm
Larry Glady
still no idea how they would come out. why cant i find or see these in the manual spent $50 on the damn thing thanx for the help dew2
smackdabtkb
I just changed these out on mine last weekend. They go where the driveshaft enters the lower unit. Under the impeller housing. Remove all that, there will be a little spring looking thing around the seal. I just used a screwdriver and slowly worked them out. There are two of them stacked on top of eachother. Removed them both. To replace, I used the exhaust tube extension that fits on top of the impeller housing to slowly drive them down. Then put the second on top of the first and repeated the process till they were both flush with the top. I could not get the bushing out for the shift lever though, there was a washer and oring that go under that thing. Couldn't free it for the life of me, didn't want to tear it all out.
Larry Glady
no smack not those we r talking seals in the powerhead assembly got mine out after soaking in wd40 a few days thanx basicly propshaft seals
Douglas Reid
smackdabtkb
This is a fairly easy item to change, but requires a bit of work. First, use a 5/16" tap to tap the old bushing from the top. Then, slip a long 5/16" bolt with, a flat washer, through a piece of wood which spans the top of the gearcase. The bolt becomes a puller and as you tighten it the bushing is pulled up and out. To replace the new bushing, use a smaller bolt from the bottom and pull it up and into the recess. Good Luck!
Larry Glady
good call Douglas tha brass was a booger i ended up doin the same but tapped brass threaded bolt and punched out.. but the seal i was havin trouble with would be behind the propin the gearcase head assy.it was behind a stainless looking washer it ca me out after soaking in wd40 a day and takein a couple wacks with a punch good luck
