77 55hp Evinrude
pkrainert
Hello,
How do I adjust the idle on my 55hp Evinrude? Its a 1977. My Tach is not working so I am not sure what rpm's I am at. I just need to get this thing to a decent trolling speed. Right now it is way to fast.
tashasdaddy
Re: 77 55hp Evinrude
on the throttle linkage, is an idle stop screw, that needs to be adjusted. when you bring the motor to idle, the screw should hit a stop, also you throttle cable may be misadjusted, not allow the link to come back to total idle. this must be adjusted in the water, not on muffs, or a bucket.
pkrainert
Ok next time I go out I will try that. I saw what you were talking about last time I went out but didnt feel like adjusting it if it was not the correct part.
